compression #'s??
Old Apr 7, 2003 | 04:31 PM
ucantZme's Avatar
compression #'s??
ok, since i have everything outta the way im checking the c/r on the 93. how many psi should a plain jane 93 Z28 have?? 125,000 miles on the clock, cyl. 1 is right at 210 psi. any help is great. thanx.
Old Apr 13, 2003 | 11:38 PM
ucantZme's Avatar
TTT
Old Apr 14, 2003 | 11:15 PM
$hawn's Avatar
From what i'v gathered anything from 130-160 seems good, and they all should be farily close on all cylinders, and a min. of 100PSI. kinda weird your getting 210, maybe your doin it wrong, i'm not sure?
Old Apr 14, 2003 | 11:30 PM
Buttercup's Avatar
210!?
The thing to look for when doing a compression test is consistency between all cylinders and/or abnormally low readings.
If you're looking to determine the health of a particular cylinder I'd recommend doing a leakdown test.
Old Apr 15, 2003 | 12:25 AM
cef97ws6's Avatar
210 is very good and very normal. You will see some differences between testers but I checked my 97 when it had less than 10k on the clock and it ranged from 205 to 208 with stock everything. With my cam now it is about 180. Anyway as mentioned minimal variance between cylinders is what you are looking for. But if all cylinders are 200 plus everything is good.
Old Apr 15, 2003 | 10:51 PM
ucantZme's Avatar
thanx fellers, and $hawn, yes i am doing it right, who was the one that was wondering how ta route a silly little tv cable?!?
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
pimpss96
Feb 12, 2015 01:28 PM
