Compression Ratio And Horsepower
Old May 8, 2006 | 08:42 PM
Fbody1's Avatar
Cool Compression Ratio And Horsepower
If I lower my compression ratio from 11.5 to 11.0 how much horsepower and torque will i lose?
Old May 9, 2006 | 08:22 AM
Re: Compression Ratio And Horsepower
Assuming you changed only CR, you're looking at about a 1% loss in thermal efficiency. But when you change CR, you often change things like quench, valve shrouding, piston dome masking, etc, which could also affect HP. It also assumes that you have adjusted the fuel and timing to optimize the CR.
For a 500HP engine, you're probably looking at 5 or 6HP.
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
surreybrad
Sep 29, 2015 09:00 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
