compression ratio calculator...
Old May 18, 2004 | 10:09 AM
simple's Avatar
"Bowling's Compression Ratio Calculator
Input Parameters Are the Following:
Cylinder head Volume (CC) = 53.10
Piston Top Volume (CC) = 0.00
Cylinder Bore (Inches) = 4.0
Cylinder Stroke (Inches) = 3.48
Deck Height (Inches) = 0.025
Head Gasket Thickness (Inches) = 0.026
Computation Results:
Computed Compression Ratio is 12.3 to 1"
is that right? seems a little high to me! prolly because i dont know the piston volume.....
what is the piston top volume with a stock short block LT1?
do i have the deck height correct also, stock short block?
Steve
calculator can be found here https://www.camaroz28.com/calcs/index.shtml
Old May 19, 2004 | 08:05 AM
simple's Avatar
any insight?
Old May 19, 2004 | 08:32 AM
kmook's Avatar
Advanced Tech Moderator
Piston Top Volume (CC) = 7.00
Example-
Cylinder head Volume (CC) = 54.00
Head Gasket Thickness (Inches) = 0.049
Computed Compression Ratio is 10.4 to 1
Old May 19, 2004 | 09:02 AM
simple's Avatar
thanks Ken, that makes a big difference. puts me at 11.1-1
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
surreybrad
Sep 29, 2015 09:00 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
