Compression Ratio Calculation
Old May 9, 2005 | 01:21 PM
Jeremy_30th's Avatar
Question Compression Ratio Calculation
Here But I'm missing some info to complete it. I have head volume, cylinder bore and crankshaft stroke but the other ones I'm not sure of. Can someone please tell me or point me in the right direction. And one more thing what is the stock head volume?
Old May 9, 2005 | 01:58 PM
rskrause's Avatar
Moderator
Re: Compression Ratio Calculation
I don't know what pistons you are using. But typical flat-tops with valve reliefs are
-5cc and stock deck is 0.020". Do a search on the CC volume, Arnie has measured it. But your's may differ if any work was done on the chambers.
Rich
Old May 9, 2005 | 03:42 PM
12.3:1 static sound logical w/below mods? Thanks rod length on stock lt-1 5.7" right
Also how do I find (Inlet Valve Closes ABDC : 0-90deg @ .050 lift)
***Trying to get Dynamic compression ratio now***
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
surreybrad
Sep 29, 2015 09:00 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
