Compression Ratio
Old Oct 22, 2009 | 09:01 PM
joshmullins8's Avatar
Compression Ratio
What should my compression be with the LT4 Hot Cam Kit,.030 Flat Top Pistons and stock heads and crank?
What should my car idle at?
Old Oct 22, 2009 | 11:20 PM
Go look at the compression ratio calculator linked on the "Automotive Calculations" link on this site (stickied at top of "LT1 Based Engine Tech" topic listings) , and see the other data you need to calculate the CR, like deck height, compressed gasket thickness and piston valve relief volume.
What did the tuner set it to idle at?
Old Oct 25, 2009 | 03:10 PM
My car idles at about 900-1000 RPMS and I cant find the compression ratio calculator I thought it would be about stock so when i had the tuner tune it I just wrote 10:5:1, will it hurt anything if I run it like that?
Old Oct 25, 2009 | 04:03 PM
It may idle at 900-1000 RPM, but what did the tuner set it to idle at? That sounds a bit high for the LT4 HOT cam on an A4.
You can't find the calculations link? There are only 4 "stickies" on the LT1 Based Engine Tech topic listing page, and this is one of them:
https://www.camaroz28.com/forums/sho...d.php?t=171795
Old Oct 25, 2009 | 11:51 PM
Im really not trying to be annoying or anything with my dumb questions its just Im only 17 and put alot of money in my car and just wanna make sure everythings so what do you think it should normally idle at? I just got a PCMforless tune and he never asked me or anything about what to set the idle at.
Old Oct 26, 2009 | 05:32 AM
ASK HIM what he set the idle at. That's the expertise you paid him for. He picks the idle setting, based on his experience.
Telling him you had 10.5:1 static compression ratio probably didn't hurt anything. A scan of the PCM would be a good idea, looking for signs of spark knock retard. If the CR is appreciable above that (and it probably isn't, but that depends on the items I listed), it might have a bit too much spark advance, but if it did, you would see knock retard on your scan.
You are over-thinking this. Does it run good, or not?
Old Oct 26, 2009 | 11:46 AM
It seems to run fine from what Ive seen, i havent tagged it up yet so Idk how its gonna run on the streets Ive only took it around the block a couple times
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
surreybrad
Sep 29, 2015 09:00 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
