Compression ratio
Old Jan 17, 2009 | 02:02 PM
01pewterz's Avatar
Compression ratio
I just figured everything I could to get my compression before I put my heads on and wanted to make sure its right.
What I have figured:
Bore: 4.00
Stroke: 3.48
Combustion chambers: 56cc
Deck Height: .018 (put at TDC and used feeler gauges to measure at top edge vs deck)
Head gaskets: .047 (9966pt)
Pistons: 5cc (flat top w/ 4 reliefs)
and I used an online calc and came up with 10.638
does that sound right? And it should run fine on pump gas?
Old Jan 17, 2009 | 02:53 PM
slomarao's Avatar
Should run fine on 93. Not sure about your math, Im no good either tho.
Old Jan 17, 2009 | 03:22 PM
94zgreenmachine's Avatar
Sounds right. I'd use the impala gaskets to squeeze a little more compression out and tighten up your quench. You would then be at 11.2:1. With a good tune, you'll be fine. I am at 12.4:1 on 93.
This site has many calculators:
https://www.camaroz28.com/services/calcs/
Old Jan 17, 2009 | 03:58 PM
01pewterz's Avatar
I was gonna go that route but I picked up this whole gasket set cheap ($50) and since I'm running out of $$ will just go with them, cause I still need to get the tb, pushrods and fluids plus the tune. Not to mention this is a DD pickup (check sig below) that will go to the track every now and then to blister some stangs
Old Jan 17, 2009 | 04:33 PM
Still not too late
http://www.superchevyperformance.com...p/12553160.htm
Old Jan 17, 2009 | 08:34 PM
01pewterz's Avatar
it is now
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
surreybrad
Sep 29, 2015 09:00 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
