compression math
Old Mar 28, 2006 | 08:49 PM
Radd's Avatar
compression math
im trying to figure out how much i need to take off the head to get 10.8:1 compression stock bottom end on a lt1. The machine shop is full of idiots and they can't do the math so im seeing if you guys can put the figures together
my head gasket is .045 compressed
how much needs to get shaved off the head for 10.8:1 compression?
Old Mar 28, 2006 | 10:27 PM
Radd's Avatar
Re: compression math
anyone here know?
Old Mar 28, 2006 | 11:05 PM
ajschult's Avatar
However much milling is required to get about 63cc combustion chambers. There is a compression calculator under the services section of this website. I just guessed and checked until the compression was 10.8 with .045 gasket thickness. I couldn't tell you how much milling gets a head to 63cc's though.
Old Mar 28, 2006 | 11:13 PM
firebirdStud's Avatar
http://www.rosspistons.com/calculator.php
Old Mar 29, 2006 | 01:00 AM
MachinistOne's Avatar
Assuming 10.5 starting compression you need to take out 2.5cc of chamber volume to reach 10.8 Those heads are most likely .006" per cc removal on flat mill so cut about .015"
That is just an estimate...with all assumptions that is as close as you are going to get.
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
whitehooptie
Jul 22, 2015 10:25 PM
13qtr
Jul 19, 2015 05:30 PM
