Compression Increase going from -16cc to -7cc dish pistons
Old Apr 4, 2005 | 12:33 AM
BlueCamaroZ28's Avatar
I am woundering what would be the compression change if swaping a -16 cc with -7cc dish pistons, assuming everything remains the same; head, cam and so on.
I have estimated 1.4 points increase in compression. Someone correct me if I am wrong.
I will be using stock LT1 pistons in a Jeep I6 4.0L engine, will be 0.125 over bore size in that engine and want to know my new compression. The stock pistons cc of the 4.0L engine is -16.
Old Apr 4, 2005 | 11:21 AM
CANTONRACER's Avatar
Re: Compression Increase going from -16cc to -7cc dish pistons
1.3-1.4 drop in compression...but it varies depending on bore/stroke, gasket thickness...etc...
Old Apr 5, 2005 | 02:47 AM
You mean increase not drop.
Great, that would put me at 10.2-10.4 compression with the LT1 pistons. Kind of high but it will work on 93 Octane gas.
Old Apr 5, 2005 | 06:37 AM
Yeah...I thought you were going from a 7 to 16 cc dish for some reason
Old Apr 5, 2005 | 08:22 AM
WS Sick's Avatar
The 4.0 has an Iron head right? I'd take a little more detonation precautions as well.
Old Apr 5, 2005 | 10:42 AM
Dave89IROC's Avatar
10.2-10.4 should be fine with 93 and an iron head, I was running 10.7 in the K5 Blazer with dart iron eagles
Old Apr 5, 2005 | 12:28 PM
WS Sick's Avatar
Combustion chamber efficency helped that out alot.
Old Apr 5, 2005 | 04:19 PM
Yes, it is. Mine is also stroked using 4.2L crank and 4.2L rods. So, it will be 4.8L with 0.125 overbore using LT1 pistons. It will be around 280HP 6-cylinder engine. Was running it for more than a year using 0.040 oversized Jeep pistons. Now I am rebuilding it cause I had a broken valve and piston.
surreybrad
Sep 29, 2015 09:00 PM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
