Compression Increase going from -16cc to -7cc dish pistons
I am woundering what would be the compression change if swaping a -16 cc with -7cc dish pistons, assuming everything remains the same; head, cam and so on.
I have estimated 1.4 points increase in compression. Someone correct me if I am wrong.
I will be using stock LT1 pistons in a Jeep I6 4.0L engine, will be 0.125 over bore size in that engine and want to know my new compression. The stock pistons cc of the 4.0L engine is -16.
Re: Compression Increase going from -16cc to -7cc dish pistons
Originally Posted by CANTONRACER
1.3-1.4 drop in compression...but it varies depending on bore/stroke, gasket thickness...etc...
Great, that would put me at 10.2-10.4 compression with the LT1 pistons. Kind of high but it will work on 93 Octane gas.
Originally Posted by WS Sick
The 4.0 has an Iron head right? I'd take a little more detonation precautions as well.
surreybrad
Sep 29, 2015 09:00 PM
