Compression
Old Dec 20, 2006 | 12:57 PM
LUCIOWS6's Avatar
Compression
Hello what is the highest compression I could run when planning to use either 91 or 93 octane gas? Thanks!
Old Dec 20, 2006 | 01:25 PM
jsetzer's Avatar
Depends entirely on how good your tune is.
I am over 13:1 but I have a decent tune and keep it nice and cool. 91 pump gas. If I put it in 6th and floor it she will detonate. But under normal driving or racing conditions its fine. Loves the bottle too.
A note on heat, my car can not over heat now simply because it wont run past @ 220. She runs 170 pretty much all the time on the temp gauge.
Old Dec 20, 2006 | 01:37 PM
LUCIOWS6's Avatar
Alright so let me get this right, I can use any compression and any fuel type as long as I get my computer tuned for it correct? Thanks!
Old Dec 20, 2006 | 02:02 PM
jsetzer's Avatar
Lol, don't just take that thought and run with it. Do some searches on dynamic compression ratio.
The rule of thumb if I recall correctly is to stay below 9.0 on your dynamic. I think a target of 8.5-9 is good. While my static is high, my dynamic actually falls about right with a fairly large cam.
What are your goals? Ever want a poweradder? Doing the whole bottom end?
Everything has to be in harmony, and that everything encompasses A LOT!
Old Dec 20, 2006 | 02:19 PM
LUCIOWS6's Avatar
YEs right now I'm in the middle of a 383 rebuild http://store.summitracing.com/partde...5&autoview=sku and a summit tech told me that my compression would be around 10.4:1 with the LE1 heads I'm going to run with. I'm just trying to hit the 400hp. I upgraded almost everything else pushrods, guideplates, nsa rockers pro mag, 30lbs injectors, 52mm throttle, borla catback exhaust, mid length edelbrock headers and I still need a torque converter(2800-3200rpm), gasket set and computer tuning.
Old Dec 20, 2006 | 03:44 PM
LUCIOWS6's Avatar
Would any of you guys know where to find a good and cheap gasket set?
Old Dec 20, 2006 | 07:08 PM
1racerdude's Avatar
Your IVC point will determine your static compression,
Ya need to stay UNDER 9.0 DYNAMIC compression on 92 octane and that's with a good tune. Ya also need GOOD cooling.
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
pimpss96
Feb 12, 2015 01:28 PM
