compression
Old May 13, 2005 | 01:04 AM
95_formula's Avatar
compression
I tested my compression today and I am at 190, the car has 100,000 miles on it. I also wanted to know how much our cars had from the factory and if thats right for the amount of miles on my car. Thanks
Old May 13, 2005 | 02:05 AM
lt1street's Avatar
Re: compression
thats what mine blow, how many pumps (cycles) did you let go when you got your reading, 3,5,7... just woundering. mine was at 3 cycles, at 165 psi and 5 about 180-190 psi and 7 was up around 200-210 psi.
Old May 13, 2005 | 02:12 PM
95_formula's Avatar
Re: compression
I dont remember exactly how many times but it was around 5 or 6 and this was the #1 cilinder
Old May 13, 2005 | 02:55 PM
OBE1 95Z28's Avatar
Re: compression
I believe the numbers will read low if you don't prop the TB blades open while cranking. It's more informative to get the reading on all 8 cylinders so you can see the variation between cylinders. I realize that's a lot more work but numbers off one cylinder could be misleading.
Old May 13, 2005 | 09:52 PM
96capricemgr's Avatar
Re: compression
Yeah what you want to do is test all and look for consistency more than anything else, and yes prop the TB open.
Old May 13, 2005 | 10:09 PM
1quikZ's Avatar
Re: compression
if theres more than a 20% differnce between any 2 cylinders you have issues,
Old May 14, 2005 | 08:15 PM
95_formula's Avatar
Re: compression
I did hold the throttle open and I know I should check all of them but I wanted to know if the number I got is good or not and what it is from the factory.
Old May 14, 2005 | 09:17 PM
Re: compression
190 is OK but that is also asuming the gauge is accurate hence the insistance that consistency is the key over just numbers. I get 195-200psi out of my 180K LT1 in my wagon but that has a little different cam which will affect readings some.
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
pimpss96
Feb 12, 2015 01:28 PM
