Completely Stumped (Rocker Problem)
Old May 21, 2005 | 11:24 AM
lookingforwheels's Avatar
All right I'm in the process of trying to fix my tapping rocker. I have the valve cover removed but with the motor running I can't tell which rocker it is. I even held up some hose to my ear and put it next to the rockers but cound'nt tell the difference. I untighented two that I thought might be the problem but I had to untighten them a lot and then they started making a clacking noise(a noise a lot different from what I'm hearing.) Then when I went to retighten them I tightend them until they stopped clacking, then went a 1/2 turn further. It feels like I didn't tighenten them as much as it took to loosen them.(Could that be a problem) Does anybody have any suggestions. Is a there an easy way to see if any of them are loose? Could there be anything else that could be making a consistent ticking noise, that is audbile from outside the car?
Old May 21, 2005 | 11:28 AM
Beyonce Knowles's Avatar
Re: Completely Stumped (Rocker Problem)
Only tried 2? Sounds like I can think of 14 other things to try
Other than that, you could try one of the 4 methods shoebox has on his site here
Old May 21, 2005 | 11:38 AM
Well the reason I only tried two is because once they were loose they made a different kind of clanking sound. Then when I went to re-tighten them I wasn't sure how much to tighten them because of how long it took for me to re-tighten them. Somebody told me to untighten them until in clicks then tighten it till it stops then go a 1/4 inch more. But it took a lot of turns to untighten so I am a little worried that they will all be a little looser then they were.
Old May 21, 2005 | 12:14 PM
All right I just went threw and loosensed, then retighted the whole passanger side, thats were the noise is coming from. But I still hear the ticking noise is there anything else I could do? I took off the drivers side valve cover and listened over there, and the noise is defenetly coming from the passenger side.
Old May 22, 2005 | 01:10 AM
dirtybird96's Avatar
check your header bolts to see if the're tight, if they are you might have a bad header gasket
Roadie
Feb 16, 2015 10:34 AM
alphaauto
Feb 5, 2015 05:25 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Jazsun
Dec 29, 2014 12:14 PM
