Comp XFI cam profiles
Old Oct 22, 2006 | 01:15 PM
gixxer92's Avatar
Anyone have the cam profiles for the 07-467-8 and 07-468-8 XFI Cams?
I have the 466 profile & the LE2.2 and want the other two specs so I can figure out a couple of things with dynamic compression. If no one has them today I will get them tomorrow from Comp.
TIA
Old Oct 22, 2006 | 01:27 PM
gixxer92's Avatar
Re: Comp XFI cam profiles
BTW I mean the complete specs @ valve lift
Old Oct 22, 2006 | 01:52 PM
seawolf06's Avatar
http://www.empirenet.com/pkelley2/DynamicCR.html
Using that program at the bottom, all you need are the advertised duration, lsa and intake centerline and it will calculate the valve events for you. Then you can use it to find SCR and DCR.
Old Oct 22, 2006 | 02:54 PM
SStrokerAce's Avatar
DCR ain't the end all be all of what makes power and torque with a cam.... don't know why you are all worried about that when all the other variables are as much or MORE important.
Bret
Old Oct 22, 2006 | 03:37 PM
The Engineer's Avatar
I'm running a Comp XFI #07-468-8, 2200-6300 RPM range (the largest of the LT XFIs, ground on a small base-lobe) in my 396 stroker and that cam is really awesome. The first time down the track it went 11.56 @ 117.41 (all N/A). Then with a little more break-in and some Sunoco 104, it went 11.22 @ 119.3 (also at a better track).
However, I now have the roll-bar issue (NHRA Rule 11.49 and below) and haven't been able to open it up again at the track. So, I've just been bracket racing in the street class and sand-bagging. Although, someone asked me a few weeks back if my car would run a 13 flat. I smiled and said, "yes it will do a 13."
Anyway, I couldn't be more happy with my XFI cam! I'm going to do a gear and slick change off season (going to 4.30s and 28" slicks) and hope to touch the 10s. Also, I'll have a Wolfe 6-point bar in the car before long.
WD
http://www.cardomain.com/ride/2189634
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
drptop70ss
Mar 26, 2015 01:50 AM
carl.froehlich
Mar 13, 2015 12:38 AM
alliance12364
Mar 6, 2015 04:39 PM
