Comp R lifters
Old Jul 14, 2003 | 04:27 PM
mastrdrver's Avatar
Comp R lifters
Will these lifters work better then a regular set of lifters for the 31xx series XE lobes? I have heard that those lobes eat up lifter.
Jeremy
Old Jul 14, 2003 | 04:40 PM
turbo_Z's Avatar
i am using my stock lifters and spin it up to 5500 rpm with the XE224/230 but the lift maxes out at around .550" i believe. a friend of mine went with stock replacement lifters and has the 230/236 with no lifter issues so far. if you are going with new lifters however then spending the extra $20? on the comp Rs probably wouldnt be a bad idea and its just extra security.
Old Jul 14, 2003 | 05:02 PM
mastrdrver's Avatar
How high does your friend turn his motor?
Old Jul 14, 2003 | 05:15 PM
rskrause's Avatar
Moderator
I used XE #3190/3192 (214/224, .530/.567") with stock lifters for two years. I had the rev limiter set to 6,200rpm and was usually shifting at 5,800-5,900rpm.
Rich Krause
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
