View Poll Results: Comp Pro-mag...How many turns past zero lash?
1/4 turn past zero lash
11
73.33%
1/2 turn past zero lash
26.67%
Voters: 15. You may not vote on this poll
Comp. Pro-mag correct lash setting........
I have run 1/2 turn past zero lash (non engine running) and not have any issues. Engine ran quiet and strong. This is what Comp reccomends for the Pro-mag rockers. I am also running the Comp 7/16" studs.
Many state that they adjust to 1/4 turn past zero lash.
Please post your thoughts.
Re: Comp. Pro-mag correct lash setting........
If you have stock lifters, and 3/8" studs, then 1/2 turn is optimal.
If you have stock lifters, and 7/16" studs, then 3/8 turn is optimal.
The difference is due to the thread pitch on the studs being different. Adjusting them this way will put the correct amount of preload on the lifters.
Dan
Dan
Assuming this thread is about Comp Pro Mag rocker arms, IMO, the rocker has nothing to do with the desired lash setting. A rocker arm will perform the same, no matter what the lash. Lash is set by lifter type or desired lash for performance reasons.
We all know what he means. Not to mention the title is not one sentence. He used ... to seperate the two.
Comp Pro-mags installed, what a pain. How many turns past zero lash?
^This could be what he is saying. You use ... to fill in the middle.
Well, I am using comp 850 lifters, started at 1/4 turn past zero, and they were kinda loud. But, my tuner said loosen them to 1/8 turn and I will pick up some power, man are they loud. But, it doesn't bother me, I am more worried about them being too loose. But, he assures me its ok to do this.. I am using the bigger studs too.
Do it with the engine running and "0" is when they STOP clacking and making noise, then 1/8 preload.
Originally Posted by 1racerdude
If ya have them 1/8th turn TIGHTER than"0" they shouldn't be noisy.
I may try to do each one individually. Like, back it off, then tighten it with my finger until it stops clacking, then take the wrench and do the 1/8th turn, then move on to the next... just alot of run time to throw oil everywhere...
What do you think?
Get ya a regular valve covers and cut the top the full length of the top of the cover minus a couple of bolt holes. Cut the sides down to almost the vertical side on the bottom. Bend the cut part back and trim some height and smooth the edges. Bolt um on and set them while they are running.
Ya need to set the preload with it running to get the lifter to back down. Otherwise they will all hold the valves open and possibly damage something or make it hard to start.
Aaront810
Aug 29, 2020 09:34 PM
tommalcolm
Sep 11, 2015 03:39 PM
