comp guid plates work fine!
Old Apr 4, 2008 | 09:59 PM
97SS0594's Avatar
got my car back togeather after my comp R's grenaded kept in the comp guide plates as my isky's havent showed up and they work perfect! just so you guys know. i define working fine as there is no rubbing and plenty of clearance throught the whole pushrod stroke.
Old Apr 4, 2008 | 10:01 PM
mdacton's Avatar
thats not the problem...the tip is not centered on the valve tip...they will either jump off and break/bend PR or wear the guides out
Old Apr 4, 2008 | 10:09 PM
guest74777's Avatar
Guest
run them for a few more miles and track passes, youll probably change your mind about them.
Old Apr 4, 2008 | 11:07 PM
No, they are not fine.
Old Apr 5, 2008 | 06:53 AM
wrd1972's Avatar
Valvetrain carnage in your future.
Old Apr 5, 2008 | 08:01 AM
NightTrain66's Avatar
remove the valve cover and look over the fender and see how the rocker sits on the valve tip. It NEEDS TO BE sitting in the center of the valve and the Comps (or any other guide plate made for a standard SB Chevy) will have the pushrods sitting off to the side a lil. This will put lots of stress on the valve and valve guide resulting in prematurely worn guides.
The isky adjustables are the best choice if you take the time to get everything centered. The best "non adjustable" guide plate to just bolt down is the Trick Flow 30400623-8 guide plates.
Here is how to get the right PR length while you are at it. . . . .
http://ls1tech.com/forums/showthread.php?t=327734
post # 5 explains it all very well. Just use a real week valve spring from hardware store in place of your valve spring. This allows you to reuse your stock hyd roller lifter with out compressing the plunger in the lifter as this would throw off the pushrod measurement.
Lloyd
Old Apr 5, 2008 | 01:14 PM
sam pace's Avatar
Get the Manley 42355-8 guide plates. I have them and they fit perfectly.
Chad at Golen uses them too.
Old Apr 5, 2008 | 01:46 PM
88IROC_Z's Avatar
not trying to steal the thread, but my machine shop is using EngineTech guideplates on my heads am I asking for trouble with these?
Old Apr 5, 2008 | 01:47 PM
dangalla's Avatar
never heard of them personally, but it might be a good idea to go with one of the well known companies listed in this thread that are known to work in a LT1
Old Apr 5, 2008 | 01:55 PM
96capricemgr's Avatar
Brand does not matter looking and making sure things line up matters. The LT1 spacing is not quite the same as what most plates are made for. I used the GMPP plates for a year and while they lined up better than Comp they were still not great, I suspect the TricFlows are the same way. That is why I went to Isky adjustables.
After 8K or something like that the GMPP did have some wear too them.
Old Apr 5, 2008 | 08:08 PM
RallyBoy1's Avatar
dang, one more issue to worry about before i order my parts
Old Apr 6, 2008 | 07:46 AM
94zgreenmachine's Avatar
I can second that. After seeing those yesterday we could only pick out some that looked better than others but all were worn pretty good!
Old Apr 6, 2008 | 08:04 AM
I should have dug out the Comps to show the different spacing. I just compared them and if you lineup one slot the other slot is by eyeball nearly 1/16" off, the GMPP ones are closer but still not quite right, meaning the Comps are way off.
Old Apr 6, 2008 | 08:13 AM
PoorMan's Avatar
My old pics. 200 miles regular driving no WOT
Comp Cam for small block chevy after 200 miles
Pushrod after 200 miles
GM LT1 plate on top and the small block chevy plate in the back with wear
liamcg97
Nov 25, 2019 05:55 PM
oldschool
Feb 9, 2016 09:21 PM
alphaauto
Jan 23, 2015 07:42 AM
Snoman73
Nov 17, 2014 07:22 PM
Ryabut98
Sep 3, 2002 11:45 PM
