Comp Cams XFI
Re: Comp Cams XFI
Originally Posted by shannons86
Why dont you tell us all knowing one. What does that have to do with a camshaft?
Originally Posted by SStrokerAce
You wanna pick a fight too? If you can't figure out what a cam and a torsion bar have in common then maybe you shouldn't be arguing with me about it.
Bret
Bret
Typical answer for someone who dosent know what in the heck they are talking about. thats like saying a leaf spring and a fender have something in common.
Shannon86, do a search for "SStrokerAce" on here and you'll see that A LOT of people here come to Bret for camshaft advice.
Re: Comp Cams XFI
I just cant believe he is all pissed off beause someone knows just as much if not more and is doubting his word. He really dosent know what he pretends to. I dont care how many post he has.
Re: Comp Cams XFI
I just cant believe he is all pissed off because...
Edit: Have no documentation as to the amount (degrees) of twist possible per 'X' amount of spring tension applied but it is a force to be recognized. A little off topic, but it can be astounding the amount of torsional crank twist that can be experienced in a fueler without it snapping. A person would not imagine this possible, but as cam twist, it is.
Originally Posted by onebadponcho
... do a search for "SStrokerAce" on here and you'll see that A LOT of people here come to Bret for camshaft advice.
Re: Comp Cams XFI
Originally Posted by A/G
As in a torsion bar suspension with stiffness affected by the dia. of the shaft, a cam's torsional rigidity is affected by the minimum dia. of the shaft. If that minimum dia. is altered due to a change in base circle dia., the shaft's rigidity is compromised. The force that would twist the cam(shaft) is obviously generated by the action of spring tension transmitted through the lifters.
ok. The barrell is always smaller than the base circle. So no matter if it is a large base circle or a small base circle the barrell is the area that absorbs the torsional twist. So again I say there is no *******way that base circle affects stiffness of the camshaft. If the cam was so large that the lobes would need to be undercut into the barrell or if the cam has been reground and undercut then it would affect stiffness.
Re: Comp Cams XFI
Again the material between the lobes is considered the barrell.Do you understand that part?
The torsional spring rate of a shaft is proportional to the 4th power of the shaft's diameter so a small change in diameter makes a big change in stiffness. Because the area between the lobes is smaller than the base circle diameter, when it is reduced even a little to allow small base circle diameter lobes, the torsional stiffness drops dramatically. A 1.00 inch diameter bar is about 52% stiffer than a .90 inch bar.
So IF the area between the lobes is reduced to clear the lifters when using small base circle lobes, the torsional stiffness IS reduced.
That's what you meant, right?
FWIW, coil springs are really torsion bars that have been coiled. The stresses in the wire are torsional.
Re: Comp Cams XFI
If the cam was so large that the lobes would need to be undercut into the barrell... then it would affect stiffness.
[QUOTE ]The barrell... base circle.
If the cam... it would affect stiffness.[END QUOTE]
You've just contradicted yourself. Maybe it is you that doesn't understand.
Re: Comp Cams XFI
Re: Comp Cams XFI
Isn't that what I just said? [QUOTE ]If that minimum dia. is altered due to a change in base circle dia., the shaft's rigidity is compromised.[/END QUOTE]
Re: Comp Cams XFI
Yes, there is always a benefit of going with more lift even if the heads do not flow more. Valve lift is not a function of flow, it's a function of area.
Bret
Bret
Re: Comp Cams XFI
But it still dosent affect stiffness if the base circle is no smaller than the barrell.
