Comp Cams XFI
Re: Comp Cams XFI
Why would you want to use the 26986-16 springs when you have the 26918-16 springs?
The Engineer, on your cam you could grind the cam with a small base circle... the real question is have to assembled the bottom end yet? It's the best thing to clearance the rods rather than reduce the stiffness of the camshaft to have it fit. Some lobes cause the cam to have a small enough base circle that the cam doesn't need to be ground with a even smaller base circle.
As I said before lift it super critial in your setup, professionally I don't think the XFI lobes will give you enough lift to get you where you want to go with a 2.02 valve in those AFR heads. Do a google search about curtain area.
Bret
Bret
Re: Comp Cams XFI
Brett, Brett, Brett, the only way a camshaft stiffness is reduced is when the lobe is undercut (into the barrell) Most samll base circles dont get into the barrell so how does that reduce stiffness when the barrell is the smallest portion anyhow????
Re: Comp Cams XFI
Ive got a 396 stroker and i ordered the XFI 579 584 from Comp Cams through summit...IT DID NOT CLEAR the rod bolts..then ordered the SAME cam but small base circle (1.050) and STILL DID NOT CLEAR.. now they are grinding me the exact same came however the new specs are..
New Grind # Directly from Comp: 3018-S/3039-S HR113+4 (Base Circle: .900)
...................... INT EXH
Gross Valve Lift: 584" 579"
Duration @.050: 242 248
Lobe Seperation: 113.0
Re: Comp Cams XFI
Originally Posted by shannons86
Bret, Bret, Bret, the only way a camshaft stiffness is reduced is when the lobe is undercut (into the barrell) Most samll base circles dont get into the barrell so how does that reduce stiffness when the barrell is the smallest portion anyhow????
White_96_SS, what rods did you put in that stroker that didn't clear?
Bret
Re: Comp Cams XFI
While spec'ing any stroker motor, one should look at rods that use capscrews and not headed bolts for the reasons listed above. The head of the rod bolt is what will hit, so better off not having one. Look for a lighter weight, high quality rod to do the job. Manly has some nice choices.
Re: Comp Cams XFI
How do you think you get a .900 base circle cam unless they reduce the size of it that much? The lobes he is looking at will easily be 1.200" or larger on the base circle, it's not the same core that they will cut the cam on going from the 1.200" base down to a .900" base circle... you couldn't do that on the same core because you would break thru the case hardening. I've had plenty of cams with 1.100" base circles that push the limits of that core... and you can't go much farther if at all on it.
Re: Comp Cams XFI
I really like the numbers on the XFI cam. Although, I haven't bought the cam yet and I'm several weeks away from the final assembly. So, you should have yours running before me. PM me and let me know what you think about the XFI when you get it running. Hopefully, Comp has figured out the small base circle now for you. I like high-torque, low-RPM stroker engines and plan to only turn around 6300 with mine. Also, a lot of people over-cam their engines these days. Good luck with your new 396 and let me know how it runs!
http://www.cardomain.com/ride/2189634
