Comp Cams and Crane Rev Kits?
Old Sep 26, 2005 | 07:25 PM
  #16
JustNO's Avatar
Re: Comp Cams and Crane Rev Kits?
Originally Posted by 1racerdude
What is the kit gonna do for the lifter's? The idea of a rev kit is to keep the lifter's on the cam IF ya float the valves. With that kind of seat pressure on anything less than a 2.100 SS valve will be fine. Your 170 will turn into 150 after break in but that is on the upper scale of seat pressure for a hyd cam.
Yeah I know.. The springs came with AFR heads and they toldme that they will change the pressure to 160lbs.. Maybe I would go with Morel lifters and forget about valvetrain.. My valves are 2.080" ..
Old Sep 26, 2005 | 07:38 PM
  #17
1racerdude's Avatar
Ya should be OK without the rev kit,unless ye are going above 7000 in witch case it won't help anyway. Hyd cams and lifters weren't made to go that high.The stock lifters will be OK if they are in good shape.Just set them at 1/8 turn after they quit clacking and don't make any noise & gotta tighten slowly.(set um running)
Old Sep 27, 2005 | 12:56 AM
  #18
SStrokerAce's Avatar
No need for a rev-kit, listen to Larry on that. The beehives are more than enough, especially with what you are getting with it ;-)
Bret
Old Sep 27, 2005 | 11:04 AM
  #19
snorkelface's Avatar
Question Re: Comp Cams and Crane Rev Kits?
Bret
A couple questions then. While the car is a high mileage daily driver, I plan on doing road racing with it with 7000RPM shifts. If you feel I don't need a rev kit, should I put that money towards something like Morell(sp?) lifters?
Also, do you feel the $100 extra cost for titanium retainers is worth the cost over the steel ones?
Thank you for the help!
Old Sep 27, 2005 | 11:48 AM
  #20
No, you don't need a rev kit.
Better lifters would always be a plus, Morel's are my first choice.
The Ti retainers help lower the mass even more, they are expensive but they do help gain that extra little bit in durabilty, valve control and RPM.
Bret
Old Sep 27, 2005 | 01:02 PM
  #21
Bret
Thanks. I always like saving money (even though I will actually spend more now )
At least now I don't have to wait for a rev kit to be shipped to me, and I can get my heads and intake sent out right away. Maybe I can put the Morel's on lay-away. Anything that is going to make the motor durable, I'm for.
Old Sep 27, 2005 | 01:35 PM
  #22
JustNO's Avatar
Bret
hey Bret I see you say no need a rev kit, but my engine is built with rev kit.. So when I get the engine by shipping should I throw away it and get a set of morels? I get it because I just wanted to be safe (and wanted to get my mind free) I don't want any big trouble because of rev kit off course..
BTW: I saw tons of people use rev kit and this is the first time I see the damaged engines by rev kit..
Old Sep 27, 2005 | 02:20 PM
  #23
1racerdude's Avatar
Ya can take it out,shouldn't be a problem.
"Tons of people"may not know they have a problem.How many ya know that have torn their engine down to see if there is a problem and if there was, did they figure out what caused the problem or could it be they blamed it on something else,ya just never know. Like I said 2 engines was enough for me,and I didn't find the problem right away,it took several days of looking and inspecting to find it.
Old Sep 27, 2005 | 02:59 PM
  #24
I swear I must be the only guy who doesn't have a problem getting those things..... you should be ok, just get them before the heads and cam get there.
Bret
Old Sep 27, 2005 | 03:11 PM
  #25
1racerdude's Avatar
Bret
Ya got an inside tract on them.
Old Sep 27, 2005 | 04:22 PM
  #26
Bret
I meant put them on lay-away because they are so dang expensive!
Old Sep 27, 2005 | 05:32 PM
  #27
Yeah just a good supplier for them. They buy a ton from Morel so it works out well for me, I never run out.
Bret
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
