comp 987's install question
Old Mar 31, 2009 | 11:55 AM
mightymouse383's Avatar
I have a set of comp 987's and have read that u have to have the spring seats cut to install then on to stock heads and then i have heard that u don't, any help would be nice. I plan on putting
Old Mar 31, 2009 | 01:03 PM
feenix88's Avatar
I had no problems
Old Mar 31, 2009 | 02:09 PM
heads needed no spring cup machine work? what size valve locks did u use, standard,+.050 or -.050, I know they are 11/32", what was the installed spring height?
Old Apr 1, 2009 | 09:54 AM
feenix88's Avatar
Heads were untouched. I think I used 10 degree locks. Here is the pn I used for the locks Comp 614-16. I didnt measure installed height because I only have the hotcam so I knew it would be more than enough. When I go bigger cam, I will measure them. I was shooting for the springs to support .600 lift.
Old Apr 5, 2009 | 02:46 PM
o.k. did u have to do anything about your spring cups/locators>? where u able to use the stock ones? what about retainers, what part number?
oldschool
Feb 9, 2016 09:21 PM
alliance12364
Mar 6, 2015 04:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
