Comp 941 install height
Old May 25, 2004 | 01:58 AM
disco192's Avatar
Ok so i bought this car and i know it has stock valves and comp 941 springs. I was wondering if anyone knows what a standard install height of these springs is. Im not sure what kind of retainers were used, but i dont think they were TI.
My main reason for asking is I have a set of 1.6 rockers and im thinking of putting these on. The 1.6 rockers would put the lift at .576. If installed at 1.8" then it would be fine because coil bind occurs at 1.130 which is .670. If it was installed at 1.75, then it would put the springs pretty close to coil bind at .576 lift.
Any thoughts?
-Stu
Old May 25, 2004 | 08:56 AM
PoorMan's Avatar
http://www.compcams.com/Technical/Cu...ML/340-349.asp
Doesn't look good.
Old May 25, 2004 | 08:58 AM
rskrause's Avatar
Moderator
There is no "correct" installed height for a given spring. You choose the installed height to give the desired seat pressure. Obviously, if the IH for the desired seat pressure doesn't give you enough travel for the amount of lift you have, you need a different set of springs. The 941 is listed as 135lbs at 1.75" and 113lbs at 1.80". 113lbs should be ok at relatively low rpm with your Ti retainers. How fast do you plan to rev it?
Rich Krause
Old May 25, 2004 | 01:01 PM
disco192's Avatar
It has a 306 cam, so im planning on reving to 6500-6600 rpm.
Old May 25, 2004 | 03:20 PM
STAR's Avatar
You should be looking for 130-135# seat pressure with that cam.
Old May 25, 2004 | 03:57 PM
disco192's Avatar
Cam doesnt affect seat pressure. Install height and spring rate/unstretched height affects seat pressure.
Cam affects lift thus open pressure.
Do you think I am ok reving to 6600?
Nov 18, 2023 07:21 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MadMav
May 25, 2015 09:35 PM
drptop70ss
Mar 26, 2015 01:50 AM
