Comments and thoughts on LCA relocation brackets
Old Feb 26, 2003 | 12:42 AM
  #16
Originally posted by Hal Fisher
I think they require a realignment between each adjustment level. I moved mine from the middle to the lowest and steering felt a little too neutral so I'll need it realigned if I want to use that position. I think you want it set to the lowest hole to help a stock center of gravity.
Hal
No "realignment" necessary. The various holes are located in the arc transcribed by the LCA as it drops. The axle position stays completely fixed relative to the body. At least the well-designed brackets (Spohn, BMR) are made this way.
Think about the function of the LCA... it is the only thing pushing the car body forward in response to the forces developed at the tire patch. Put the axle connection below the level of the body connection, and the forces in the LCA lift the body and force the tires down = traction. Locate the axle connection above the body connection (or have it reach this position as the body squats on launch) and the forces in the LCA push the body down, and lift the axle... tires lose traction.... forces disppear... tires regain traction and the whole thing starts all over again = wheel hop.
Good idea for a lowered car, or for one that isn't lowered, but is putting decent power to the rear wheels.
Old Feb 26, 2003 | 03:17 AM
  #17
SStupid's Avatar
Adjustable LCA
I bought the Spohn adj LCAs and weld-in relocation brackets as a kit, but I don't understand why the LCAs are adjustable. Could someone help me with this? I have them set to the stock length. If I am supposed to adjust them, how do I do it? Where do I measure from? Why am I adjusting them? So forth. Thanks much.
Old Feb 26, 2003 | 04:35 AM
  #18
anaik's Avatar
Re: Adjustable LCA
http://web.camaross.com/forums/showt...djustable+lcas
HectorM52
Jun 23, 2016 08:42 PM
lbrowne
Nov 13, 2011 04:25 PM
94B&RZ-28
Dec 22, 2008 10:00 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
