cometic head gaskets
Old Dec 21, 2004 | 08:45 AM
Fast Orange's Avatar
whats everyones opinions/expiriences with cometic head gaskets? im running high compression with spray and was wondering if these are worth the money.. the last motor went because of the head gaskets, dont want to make the same mistake twice..
Old Dec 21, 2004 | 09:46 AM
crash4cyl's Avatar
Re: cometic head gaskets
they'll be a good option for you then. They're the tri-metal like the stock LS1 headgasket. Very good for holding in boost and high chamber pressures like a nitrous motor.
I'm going to use them on the 95 with a 383 twin turbo setup.
Chris
Old Dec 21, 2004 | 11:32 AM
rskrause's Avatar
Moderator
If you use them the head and block deck prep must be right on - smooth and flat. If not, they will seep.
Rich
Old Dec 21, 2004 | 12:32 PM
BlownF1's Avatar
Do a search on Cometic and you'll find some fairly recent posts from those of us running them. No problems here...
Old Dec 21, 2004 | 01:19 PM
stew's94z's Avatar
Rich
What the good Doctor said is true.
My machinist decked my block with a finish for Felpro 1074's.
I decided to switch to Cometics without consulting him about the change and the gaskets seeped oil on the engine stand just by turning the motor over by hand.
Luckily I caught it and switched back to the Felpro's before installing the engine. It never seeped again.
Dean
Old Dec 21, 2004 | 01:30 PM
AlmostfastLT1's Avatar
The comestics are awesome I am using them on my new 355. They are expensive but, they pay from themselves cause you can reuse them.
Old Dec 21, 2004 | 09:04 PM
n2oCamaro's Avatar
I have them. My engine builder specified them in the build of my 383. 12.8:1 comp and a 200 shot
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
