cometic head gaskets
whats everyones opinions/expiriences with cometic head gaskets? im running high compression with spray and was wondering if these are worth the money.. the last motor went because of the head gaskets, dont want to make the same mistake twice..
Re: cometic head gaskets
they'll be a good option for you then. They're the tri-metal like the stock LS1 headgasket. Very good for holding in boost and high chamber pressures like a nitrous motor.
I'm going to use them on the 95 with a 383 twin turbo setup.
Chris
Chris
Originally Posted by rskrause
If you use them the head and block deck prep must be right on - smooth and flat. If not, they will seep.
Rich
Rich
My machinist decked my block with a finish for Felpro 1074's.
I decided to switch to Cometics without consulting him about the change and the gaskets seeped oil on the engine stand just by turning the motor over by hand.
Luckily I caught it and switched back to the Felpro's before installing the engine. It never seeped again.
Dean
