Cold start bottom end rattle.....
Old Nov 7, 2003 | 05:24 PM
Sleeper_Z's Avatar
Well I fired my car up this morning and I just did an oil change and I put in the usual Valvoiline 10W30 and now at about 2K thru 2500 in first I have a light but noticable rattle till the motor warms up to normal operating temp (about 170-180) and the oil pressure drops down from about 60-70psi (when cold) back to 20-30(when warm). How long will it last like this if i take it easy? Is it too late to stick a new set of bearings in it? Thanks for all your help.
Jeremy
Old Nov 7, 2003 | 05:48 PM
JDBlaze85's Avatar
let a good mechanic listen to your engine.
if it is noise in the bottom end, thats serious s***
cheaper to rebuild a working engine than a blown one!
Old Nov 8, 2003 | 04:51 PM
steelheart's Avatar
Re: Cold start bottom end rattle.....
Jeremy
dont worry about the noise, my 96 ss makes the same type of rattle when cold and my old 95 that i bought brand new made the same noise as well, i always thought it was a rod knock and when i went to the dealer to have it looked at they said it will make that type of noise for a few min untill the exhaust heats up, has something to do with the flow of the gasses when the engine is cold, sounds weird i know but i got this info from a gm tech who has been at the same chevy dealer fo the last 30 years... so i dont even worry about it and my cars have been fine for many years
Old Nov 8, 2003 | 07:59 PM
Stoopalini's Avatar
The LT1s are pretty bad at piston slap when the motor is cold. If you're hearing that, don't worry about it.
Mine does that every morning, always has. I take it easy on the throttle and shift at low RPMs (<3000) until it heats up. It doesn't seem to make as much noise in the lower RPM band.
Thomas.
Old Nov 10, 2003 | 05:00 PM
Sleeper_Z's Avatar
Thanks for the info guys, I was really worried. This is my first winter with my LT1, had an L98 befor, and I noticed that the other day. The noise made me really sick. I was already priceing rebuild parts for a 396 lol. Still might build the 396 though. HEHEHE. Thanks agian.
Gtpguy
Jan 26, 2015 04:50 PM
Jan 23, 2015 01:13 PM
Killer94z
Jan 13, 2015 12:06 PM
jrp4uc
26
Jul 9, 2002 04:37 AM
