Cold misfire under 2500 rpm, 94 LT1
Old Jul 26, 2010 | 01:00 PM
94Camaro_Z_28's Avatar
My lt1 (GM847, LT headers, 1.6rr, Mad Z28 tune) has started to misfire when it is cold. Opti, plugs, wires have been replaced, and I've swapped the coil and ICM with the ones off my friends car with no improvement. The car feels like one or two cylinders are not firing when it is cold.
Once the car goes into closed loop, the problem is gone. Also, if I press the pedal down, the problem goes away. Does not matter how much load is on the motor or what gear. It doesn't miss at idle, but as soon as I go in 1st gear it starts until 2500 rpm or so.
Any ideas?
Old May 5, 2011 | 12:47 PM
Re: Cold misfire under 2500 rpm, 94 LT1
Bump. Anybody have any input now?
Old May 6, 2011 | 12:03 AM
94QuasarZ's Avatar
Have you scanned it for codes?
Old May 6, 2011 | 09:13 PM
No codes present other than a 36 high res pulse failure that started months after this. I put a new Opti on it today and it cured DTC 36, but the misfire remains before closed loop. This one really has me stumped
rideordie
Nov 5, 2019 04:52 PM
AdsoYo
May 2, 2018 03:21 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
