cold air intake
Old May 24, 2008 | 08:20 PM
remy2435's Avatar
cold air intake
a buddy of mine recently purchased a chrome cold air intake of ebay, i told him not to and by from a reputable company but he didnt listen. well we installed it in place of the factory and then i realized there was no plug for the IAT sensor. well we started it up and it ran fine, then when we drove it, it would shift oddly and then the service engine soon light came on. does the iat sensor cause this, has anyone else experienced this. any help would be appreciated greatly, thanks.
oh and his camaro is a 97 z, same as mine, but bone stock
Old May 24, 2008 | 08:28 PM
caldercay's Avatar
Absolutely.
Are all other required connections on the intake? You can move the IAT
further upstream, closer to the actual air inlet. The PCM uses feedback
from the IAT.
(Sidenote: my bike has an IAT, which I've modified with a variable resister
in-line to deal with the harsh temperatures with the south-central Texas heat).
Old May 24, 2008 | 08:35 PM
remy2435's Avatar
the breather tube is on the intake, but thats it. can we take the whole sensor and move it somewhere else, but where, im somewhat mechanically inclined but he has no idea. my cold air came with the place for it. but his didnt.
im completely stumped. my only thought is to do what you said and move it. how would i do this in detail. thanks.
Old May 24, 2008 | 08:52 PM
caldercay's Avatar
Many folks move the IAT to where "colder" air would be, which would
mean moving in front of the MAF. This is the obvious, stock, location:
http://shbox.com/1/iat.jpg
You can move it anywhere along the intake tubes. Obviously, you will
have to build a "wire extension" if you move it upstream, closer to the
filter. You will need some sort of grommet (possibly) so that the IAT
will fit tightly within it, and then that grommet will fit wherever it is
along the intake tubes you have decided to move it.
Old May 24, 2008 | 08:56 PM
remy2435's Avatar
i have no idea what you mean by any of that. im sorry
Old May 24, 2008 | 09:04 PM
LOW-LIFE's Avatar
he means the sensor can be moved basically anyplace that you want but the wire it attaches to is only so long so an extension may be needed depending on how far from the stock location you decide to put it.
so long as the sensor is plugged in and getting a reading to the computer the SES light should not come on. even if the sensor is just sip tied to the filter element.
Old May 24, 2008 | 09:07 PM
caldercay's Avatar
I'll be moving my IAT tomorrow, so I'll take photos and do a write
up on the procedure.
Old May 24, 2008 | 09:11 PM
Counted Out's Avatar
Isn't the IAT sensor on the elbow, not the cold air intake?
If so just use the stock elbow with the rest of the Cold Air Intake.
Old May 24, 2008 | 09:27 PM
remy2435's Avatar
i got it. thanks, i moved it back to its stock locale in the elbow. no how do i go about getting the ses off. whats the easiest way. thanks for all your help. its most appreciated. thanks
Old May 25, 2008 | 10:28 AM
If the SES light is on, there is still an active problem. It will turn itself off if you fix the problem. As long as his IAT sensor was still plugged into the harness, it would not have set a code. It doesn't have to be physically in the air stream to the engine. If its a speed-density 93, it will screw things up though, if it wasn't reporting the correct inlet air temp. On the MAF cars, the impact would be neligible.
Old May 25, 2008 | 06:35 PM
Don't you have to disconnect the PCM from the Battery and then the code will clear (or return if it is still there)?
Old May 25, 2008 | 07:59 PM
LOW-LIFE's Avatar
no you do not.
30thZ4C
Dec 26, 2014 05:09 PM
thenewkid
Nov 27, 2014 09:41 AM
94z28jbw
Sep 8, 2002 03:22 PM
ezcheeze15
Aug 26, 2002 01:28 PM
slothgrant
Aug 22, 2002 03:01 PM
