Coil went out at high rpm car backfired and will not start
Old Oct 21, 2009 | 09:15 PM
remaxracer45's Avatar
Unhappy Coil went out at high rpm car backfired and will not start (injuneer or shoebox?)
I have the car in my sig. I was in the gas and the car back fired ran like poop for 1/2 mile, then died. Wouldn't restart, discovered the coil died and had no spark. I replaced the coil have spark and it will not start. seems like it wants to backfire when I stop cranking it over. Also smells real rich out tails. Please help! Pulled one plug looked good not fouled.
Old Oct 21, 2009 | 09:16 PM
I was not using nitrous and I don't have a timing retard yet. have a msd 6al which I did try to bypass no change.
Old Oct 21, 2009 | 09:46 PM
Dave1980's Avatar
do you have spark coming from opti? It seems your getting spark at coil wire now, but maybe a rotor problem?
Old Oct 21, 2009 | 10:17 PM
I am getting spark at the spark plug.
Old Oct 22, 2009 | 10:17 AM
jsetzer's Avatar
Check fuel and compression. Those are the other 2 out of 3.
I had a bad ICM do something similar. There was some spark but very poor and at the wrong times. I would check that too.
Old Oct 22, 2009 | 10:35 AM
seems to be plenty fuel and I have pulled 4 of the 8 plugs and they seem fine. will pull the other 4 soon. its a pain to do a compression test on these so thats my last resort. why would I have bad compression. I don't suspect any piston or ring damage as it wasn't smoking when it finally died
Old Oct 22, 2009 | 12:08 PM
Sleepy_Z's Avatar
try using starter fluid.
if it starts then you're not getting enough fuel
if it doesn't start then it could be the opti
I'd also pull off the intake tube and check the MAF.
Old Oct 22, 2009 | 12:23 PM
just tried that no go, kinda acted like it wanted to go a little. when I pulled the plugs they were wet and you can smell gas. that was before I tried starter fluid/
Old Oct 22, 2009 | 01:30 PM
97WS6SCharged's Avatar
Did you pull any codes from the PCM? If it backfired & shut down then it should have some sort of fault code.
Old Oct 22, 2009 | 10:53 PM
can I pull codes with a scanner if i can't start it? don't have one maybe autozone has one in their loaner program
Old Oct 23, 2009 | 09:17 PM
jay_lt4's Avatar
when the car backfired it is posible it damaged the MAF , or created a large air leak from the throttle body to the maf,,, check the tube from t/b to maf, and try another maf( the maf is the same as any 4.8, 5.3, 6.0L silverado / GMC truck 1999 and newer)
Old Oct 23, 2009 | 09:24 PM
bubba4's Avatar
Sounds like the screws let go on your rotor in the opti.
Old Oct 23, 2009 | 09:29 PM
jay_lt4's Avatar
this is possible also, the opti was a brand new vented gm unit when i built the engine, but it always had a slight noise to it
Old Oct 23, 2009 | 10:36 PM
I had the elbow off its a coated trickflow and I didn't see any thing inside, I will try a diferent maf the guy that has my old 97 will let me borrow it. I did for ****s check the fuel pressure 40 pounds. if the screws in the rotor let go would I still have spark at the plugs? I am gonna get a code scanner and see if there is anything there. Jay I replaced the opti with a new gm unit when I replaced the ignition box with the msd 6al and went with otvc msd wire kit. The only thing I didn't replace was the coil and that was on the list. (I hate being too late) This was all less than a year ago. The old opti is on the shelf and it seemed to have alot of play.
Old Oct 24, 2009 | 12:39 PM
I also looked at the inside of the maf and no sign of damage
