Codes like a mofo
Old Nov 2, 2005 | 08:11 AM
DSIM's Avatar
Codes like a ****
Alright, got random missfire.....idle speed sensor, and O2 bank 1 sensor 1. Any ideas? The miss seems to get progressively worse the higher the rpm. Could it be just plugs? or plugs and wires?
Old Nov 2, 2005 | 09:12 AM
Re: Codes like a ****
Generaly help if you provide the actual codes.
Old Nov 2, 2005 | 09:29 AM
DSIM's Avatar
P0030 - Heated Oxygen Sensor (H02S) Heater Control Circuit Bank 1 Sensor 1
P0300 - Engine Misfire Detected
P0506 - Idle Speed Low
P0131 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 1
Old Nov 2, 2005 | 08:29 PM
DSIM's Avatar
Would the O2 cause a missfire? When the engine is cold, it seems to run fine. Consequently... .when the engine warms up, and I assume that the system goes closed loop, the missfire starts to happen. I am just wondering what to deal with first, plugs and wires or O2's.
Old Nov 3, 2005 | 08:41 AM
Could you possibly mean P0135 = B1S1 O2 sensor heater circuit? There is no P0030.
This means the O2 sensor voltage is staying below 200mV. That erroneously tells the PCM that Bank 1 is running lean, and when it goes into closed loop, it pours unneeded fuel into that bank, probably enough to make it misfire.
You need to figure out whether its a sensor problem or a wiring problem. You could swap the precat O2 sensors side to side and see if the problem follows the sensor (sensor problem) or stays on Bank 1 (wiring problem, or actual engine problem causing low sensor voltage and sluggish warmup of sensor). Or, check the wiring harness to make sure you have +12V being supplied on the heater circuit (brown wire on the harness, pink wire on the sensor). Make sure the black harness wire is providing a good ground.
P0300 - Engine misfire Detected
Solve the O2 sensor problem first, that might cure the other two. Or, the O2 sensor problems may be the result of something else, like a complete lack of fuel or a huge amount of excess air on one of the cylinders on Bank 1. Try and rule out the O2 sensors first.
Old Nov 3, 2005 | 09:37 AM
DSIM's Avatar
Well, i thought that might be the problem. However, I drove it to the store this morning just to test it out, and the miss was happening as soon as I was driving away. No way it was in closed loop that quick... so I bought some plugs to see what happens. Just need to wait for the headers to cool off then I will get down to it. Thanks for the tips.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
