Codes 26, 27
Old Nov 3, 2013 | 07:55 AM
Chet1185's Avatar
Codes 26, 27
I did do the egr delete and haven't had it tuned yet. Is the other code because of that also. I clear the codes and they immediately come back.
I did replace the purge solenoid with a different one and the code still comes up.
Sent from my R800x using Tapatalk 2
Old Nov 3, 2013 | 10:20 AM
Re: Codes 26, 27
You can look them up on Shoebox:
http://shbox.com/1/Dtcs.htm
For the EVAP and EGR solenoids. Did you also delete the EVAP system?
Old Nov 3, 2013 | 12:20 PM
Chet1185's Avatar
Re: Codes 26, 27
I only deleted air and egr. Besides the solenoid is there anything else to replace for the evap code?
Old Nov 3, 2013 | 01:26 PM
Re: Codes 26, 27
The electrical circuit for the EVAP purge solenoid does not match the commanded state. There could be a short in the wires, an open in the wires or an electrical fault in the solenoid. OR maybe it's not plugged in.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
