codes 13 and 63..
Old Jul 1, 2003 | 05:31 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
codes 13 and 63..
I know they are o2 failures, but I need more details. Heathers car is running like *** after an over heat, although it doens't seem to be burning coolant, nor running hot(anymore) i am suspecting a head gasket.
Anybody have a GM book they can give me more details on those codes? my book is at my shop right now.. thanks
Old Jul 1, 2003 | 06:08 PM
n2ceptor's Avatar
All I have is the Haynes , code 13 says its the circuit, and 63 is the right bank heated/open circuit indicated......check for loose or broken connectorssss.....
Hope this helps....
Old Jul 1, 2003 | 09:32 PM
red90sixspeed's Avatar
I know its a PITA but if you suspect a head gasket do a comprssion check and go from there. it'll run like *** if the o2 signals are way off or the cats could have gotten clogged.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
