Code PO171 and PO174
Old Oct 22, 2004 | 01:18 PM
Kevin97Formula's Avatar
Unhappy Code PO171 and PO174
My dreaded Service Engine Light has come on. I had the car scanned and it is indicating a "Lean Condition" on Bank 1 and Bank 2.. Anybody have an idea as to what is causing the the lean condition? Thanks
Old Oct 22, 2004 | 02:35 PM
Re: Code PO171 and PO174
Low fuel pressure would be one possible cause. Have you noticed any weakness or missing at higher RPM/high load? Have you checked the fuel pressure?
Old Oct 22, 2004 | 02:40 PM
LT4383's Avatar
Dirty M.A.F. ?
Old Oct 22, 2004 | 09:30 PM
Thanks for the replies. I have already cleaned the MAF. Service Engine Light still comes on. I have not checked the fuel pressure, but I have no stumbling or sluggishness at high RPM. If the fuel pressure was low, what would cause this? fuel pressure regulator??
Old Oct 22, 2004 | 11:47 PM
Weak pump, dirty filter.
Have you checked the inlet bellows for a tear? Any chance you have a large vacuum leak?
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
