code p1351
Old Feb 16, 2014 | 07:30 PM
blackblur1996z28's Avatar
code p1351
Hey all. I replaced my opti and water pump this week. 1st time I started it up I got an immediate code of p1351. I had the icm tested and it was ok... its brand new. So im at a loss. The car runs and starts good. The clerk at AZ said that the wiring harness might have a short? Are those easy to replace? Just wanna get my baby back! Any help is appreciated
Old Feb 16, 2014 | 07:59 PM
1996LT1Z28's Avatar
Re: code p1351
I would check the wiring around the coil / ICM. Coil could be weak. Check the ground wiring for sure.
Checkout shoebox's site below.
http://shbox.com/coil/coil.htm
Old Feb 16, 2014 | 08:18 PM
Re: code p1351
Coil is new. The mechanic replaced it slong with the icm. So maybe he shorted my wiring harness out?
Old Feb 17, 2014 | 12:59 PM
Re: code p1351
Confusing - You indicate you got the P1351 on initial startup, checked ICM and it was OK. Then you say "The car runs and starts good." Are you still seeing P1351? Have you cleared it? Is there any evidence of a problem besides the code?
Old Feb 17, 2014 | 03:47 PM
Re: code p1351
Originally Posted by Injuneer
Confusingit up- You indicate you got the P1351 on initial startup, checked ICM and it was OK. Then you say "The car runs and starts good." Are you still seeing P1351? Have you cleared it? Is there any evidence of a problem besides the code?
I cleared the code. Then started It back up and It came on right away. Other than a little hesitation on cranking it fires up and runs great so far. I haven't driven the car yet, just started it a couple of times. I pulled the icm out yesterday and had them test it 10x and it was good. Could it be my wiring harness or the new coil? thanks for replies
Old Feb 17, 2014 | 04:13 PM
Re: code p1351
I would check the spring tension of the ICM connector terminals and maybe take a close look at the integrity of the connector wires to the terminals.
Old Feb 17, 2014 | 04:35 PM
Re: code p1351
The little clip that holds the icm harness into the icm is broken. The harness stays in there good but it does come out with an easy pull. The wiring looks decen and somewhat pliable
Old Feb 17, 2014 | 04:50 PM
Re: code p1351
Just checked the tension inside the terminals and each one grabs onto this tiny scrrewdriver I used.
Old Feb 17, 2014 | 05:29 PM
Re: code p1351
A new pigtail would be a cheap attempt at a fix. Something appears to be losing contact ar the first turn of the key.
Old Feb 17, 2014 | 06:40 PM
Re: code p1351
Ok...I will try that. Hopefully it works! I miss driving it...been down 4 months!
Old Feb 25, 2014 | 09:54 PM
Re: code p1351
Update
I installed the new pigtail and started it up. It was a hard start but it fired up. The p1351 code came right on immediately. The car ran good though. I shut it off and cleared the code. I then went to try to start it back up and it would only crank. After 5min went past I tried to start it again and it started and ran really well. The p1351 came back however so I cleared it once more. Could I have a bad "new" icm? It does say "made in taiwan" on it LOL.
Old Feb 26, 2014 | 08:23 PM
Re: code p1351
I'm probably just going to order an AcDelco ICM from Summit...maybe a Delco coil too. Get that foreign junk outta there. I think it's causing this problem since it always started up ok with the old stuff. All these problems started when my opti crapped out and wasn't getting spark to Cyl 2 causing a missfire. Damn! I wish i had asked for my old parts back. Oh well...at least the car has a new opti, wp, plugs, wires, and hoses.
Old Mar 6, 2014 | 09:31 PM
Re: code p1351
Update
It was either the ICM or the coil. I replaced the made in Taiwan junk with AC Delco parts and bam the light isnt on anymore. It also starts right up now. Hope this post helps out someone with similar issues! Glad to have her back!!!
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
