Code p0100 MAF
Old Feb 20, 2004 | 09:45 AM
93transam1234's Avatar
Code p0100 MAF
well i put Autotap on my car and code p0100 cam up some thing about the MAF, can anyone give me more detail of what this code means,
Also what should my maf readings be at idel on a-tap
Old Feb 20, 2004 | 02:02 PM
koochiekilla's Avatar
I believe its maf insifficient signal. had the same code pop up on me. injuneer said 2 me 2 check the voltage in the mak adapter wires. a +12 should b in the pink wire. i myself have yet 2 do this, dont have a volt meter. but what i did was give it a good cleaning. since then the code never popped up again. hope this hepls. peace. R.C
Old Feb 20, 2004 | 02:46 PM
Transamdriver's Avatar
Mine did the same thing on my yesterday and I was getting current on the pink wire. I guess I will try cleaning it later.
My code was Mass Airflow system failure.
Old Feb 20, 2004 | 02:54 PM
96ta(nick)'s Avatar
I had that code and the car was running like crap.... I opened the hood and plugged in my maf
Old Feb 20, 2004 | 03:19 PM
LOL well my SES light didnt go or anything ill try cleaning it
Old Feb 20, 2004 | 03:29 PM
Zeueses 97 RamAir's Avatar
just repalced
Mine did that last week just repalced mine I have 2 of them brand new if you need one call me 972-824-0793 angelo i tried to clean mine measured the voltage from black ground pink hot voltage was ok. it means its going out. you can pull the fuse and it might go away then it comes back. but I have an extra one if you need it..
Old Feb 20, 2004 | 04:01 PM
Yeah mine is toast it read a constant 511 gm/sec at idle. Didnt fluctuate at all. Oh well I bought one off a board member already.
Old Feb 20, 2004 | 09:27 PM
showtime89's Avatar
Same code for me today. Though I think it's cause I put too much oil on my filter when I cleaned it last week.
Dzmaro
May 7, 2015 09:33 AM
lt1matt
Mar 21, 2015 07:35 PM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
Jul 4, 2005 05:00 PM
