CODE 83 what its it, how do i fix it
Old Aug 18, 2003 | 09:16 PM
1994TransAm's Avatar
my scanmaster is reading code 83 in my 94 lt1.
friends say its somethign to do with the converter. i have a 3000 stall? and i just did a cam swap, bigger cam program and i got this code. what does it mean.
Old Aug 18, 2003 | 09:30 PM
Harpoon Flyby's Avatar
According to my Haynes manual, Code 83 is defined as "Reverse Inhibit System" (manual Trans, 5.7L0 "Vehicle must be operating under 4mph to allow reverse selection." Doesn't sound like it's your problem if it's for maunual trans... Sorry.
HF
Old Aug 18, 2003 | 09:37 PM
Dave Feerst's Avatar
DTC 83 - Reverse Inhibit System (Manual Transmission) <<<<<<<<<select>>>>>>
DTC 83 - TCC/PWM (Auto Trans)
It has somthing to do with your torque converter clutch, either its not locking up or its staying locked up when you brake or somthing else. Im not sure what PWM means, mabye, pulse width modulation? The 4L60E does pulsewith modulate the accumulator pistons, is could be somthing to do with that.
Old Aug 19, 2003 | 06:06 PM
94ZVert's Avatar
This link will help you in trying to read your codes..Scanmaster.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
Timberwolf
Aug 18, 2002 07:39 PM
91Bird305
Aug 5, 2002 01:39 PM
MislMan
Jul 19, 2002 11:41 AM
