Code 67.....
Code 67.....
A\C transducer degraded.
What the heck does that mean?
EDIT:67 - A/C refrigerant pressure sensor circuit, pressure sensor or clutch problem.
Just great!!!!!!Now as she hits 70k miles all the problems start.
Originally posted by shoebox
A/c pressure sensor circuit problem. Either your a/c clutch is not engaging or the pressure sensor is not seeing any pressure change when the a/c is actually on.
We evacuated the system last May when we did the cam swap.Recharged with the recharge kit from autozone,but no deal it was blowing warm air,so I never used the ac last summer.Now I have a bigger problem if the clutch is gone right?
Does the a/c clutch ever engage, now? Did you force engagement of the clutch when you recharged it, so it would accept the charge?
I have heard that you have to reset the pcm before it will allow the a/c to work again after it has been de-pressurized and refilled.
Originally posted by vampyr95Z
I was not aware of this.Do you think its to late to reset the pcm to accept this?
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
BigDarknFast
3rd Gen / L98 Engine Tech
Jul 8, 2002 01:37 AM
