Coolant in oil again!!!
Old Apr 24, 2003 | 05:40 PM
94 CAMRO Z28's Avatar
Angry Coolant in oil again!!!
Thought I had a leaking head gasket, so I changed that out about 2 weeks ago. After that everything was fine, no more moisture in the oil. No more steam when I took the cap off the oil filler tube. Well I checktoday and theres a ton of white/yellow gunk inside the oil filler tube!! How can this happen again?!? This all started shortly after I did the hotcam swap last year. Is it possible the thread sealer on the waterpump gaskets was leaking that coolant could get into the oil somehow through that? I know that sounds dumb but I didn't put more sealer on them after the camswap.
Aaron
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
FredM
Jun 5, 2015 05:45 AM
Nickster 7
May 1, 2015 09:04 PM
MattFick
Feb 15, 2015 10:16 PM
