Code 48 (OBD-I)
Old Feb 19, 2004 | 04:37 PM
Transamdriver's Avatar
Code 48 (OBD-I)
MASS AIRFLOW SYSTEM FAILURE.
This means I need a new MAF correct?
Old Feb 19, 2004 | 05:34 PM
Not necessarily. Check for 12v on the pink wire when the key is ON.
Old Feb 19, 2004 | 05:41 PM
I will as soon as I get a tester.
Old Feb 19, 2004 | 05:57 PM
Man I just went and re-checked all the connection and then cranked it and it is running so rich it is rediculous! There was pure fuel smoke comming out of the exhaust and it made my eyes burn. I smell like gas bad too.
Old Feb 19, 2004 | 07:39 PM
Alright I checked the power and it is getting power to the MAF. Before today sometimes the engine would stutter or miss randomly but go away and be normal. One morning it did it and the SES light came on when I was idling warming the engine. I gave it 25% throttle for about 10sec then it cleared up and the SES light went off.
Today it did the same thing but started to miss fire even more frequent and then the SES light came on and wouldnt go off and now its telling the pcm to inject so much gas Im afraid I will get cylinder wash if I run the engine.
So Im guessing since I checked both grounds and the MAF is getting power my MAF is toast. Another oddball is even when I unplug the MAF it doesnt revert to speed density, or does OBDI not do that?
Yes the MAF is ported, but it has been for at least 2 years.
I do have a laptop with FreeScan, TTS datamaster etc if need be I can check other things.
Old Feb 19, 2004 | 10:27 PM
Dont wanna seem pushy, but I just need to know if I need to get a new MAF or not.
Thanks!
Old Feb 19, 2004 | 10:39 PM
JDBlaze85's Avatar
sounds like its toast man.
Drive the car with the MAF unplugged to prevent the rich condition until you fix the prob.
Old Feb 19, 2004 | 10:52 PM
Im gonna try that tommorow, they TR6's are on the verge of being fouled anyways.
cmdeshon
Jan 4, 2015 11:15 AM
johnsocal
Aug 29, 2002 10:01 AM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
