code 48 maf sensor circuit. --
Old Apr 26, 2004 | 09:50 PM
sabre81's Avatar
im getting this code. I did drop my maf from about 4 ft off the ground onto my garage floor so this probably caused the maf to die correct? I am getting voltage at the connector that plugs into the maf so it has to be the maf sensor. My question, what should i replace it with? stock? aftermarket? and why the hell are they so expensive? i dont want to drop 270 bucks on a sensor. my cars performance hasnt suffered yet.
thanks
Old Apr 26, 2004 | 09:53 PM
ibanez6rg's Avatar
Get a stock replacement... You'll probably want to pick up a used one.
Old Apr 26, 2004 | 10:21 PM
juiced_lt1's Avatar
when you throw 48, you also enable the 'feds', and if I'm correct, your pcm uses a correlation between rpm and throttle position to guesstimate the amount of air going into your car, instead of getting a reading from your maf. I'd get a stock maf and stick to tuning your pcm for power gain. Get a used one if you can.
Old Apr 27, 2004 | 12:40 AM
HBHRacing's Avatar
Re: code 48 maf sensor circuit. --
lol.. yeah probably.. but just to be sure I would read over this real quick and double check a few things
http://mainstreamtopics.com/forum/in...?showtopic=207
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
3TAS4ME
Apr 15, 2015 02:24 PM
QuickSilver02
Apr 7, 2015 11:12 AM
pete53
Dec 9, 2014 07:31 AM
Rich_z28
Sep 13, 2002 03:35 PM
