Code 48
Old Apr 12, 2003 | 06:26 PM
chevy94c's Avatar
Unhappy Code 48
Well i went to start my car up from winter storage and 1st the battery was dead. Than i got the car running and the service engine soon light can on and i check the scanmaster and it came up with a code 48. I noticed that the MAF had 00 the whole time it was running and the fans where both on. Than i turned the car off and started it back up again and the SES light was gone & the MAF was moving know a little but the code still there.
What could be wrong? wiring, maf
Old Apr 13, 2003 | 12:38 AM
Even if you correct the problem (or it corrects itself) the code remains "stored" until you clear it (remove power from the PCM, or reset it with a scanner), or until the car is driven for a number of "drive cycles" without the problem showing up again.
What does "moving know a little" mean? Is it showing the correct GPS air flow or isn't it? If it doesn't appear right, check the MAF... maybe some mice built a nest in the intake while it was in storage..... .
Old Apr 13, 2003 | 09:30 AM
chevy94c's Avatar
Injuneer for the maf readings it only went to 06 on the scanmaster. Hopefully you are right maybe a mouse made a a home in there.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
