code 44
Old Jun 16, 2003 | 07:30 AM
Max 93's Avatar
code 44
what would cause my car to throw a code 44? I think is means the left bank is lean.
Old Jun 16, 2003 | 07:47 AM
You might try looking for any exhaust leaks.
Old Jun 16, 2003 | 08:22 AM
Bastardcat's Avatar
I threw a Code 44 (and Code 64) when my oxygen sensors took a dump.
Old Jun 16, 2003 | 09:39 AM
Gripenfelter's Avatar
You might have burned one of your O2 sensor wires on that side. Make sure they aren't touching the header or y-pipe.
Old Jun 17, 2003 | 12:22 AM
Max 93's Avatar
I did have an exhaust leak but I fixed it and it still throws the code. Both o2 sensors were replaced last summer but I don't know if the used cheap-o ones. I'll check to see if it may have burt through the wire. thanks
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
