code 36
Old Jul 31, 2013 | 06:35 PM
NUR2S's Avatar
code 36
94 z28 hard starting but when does start ses light and fans come on-car runs fine without any miss-scanner shows code 36-only add-ons to car are bbk headers and moroso cold air intake-checked wiring connections and plugins-don't know what to do next
Old Jul 31, 2013 | 09:33 PM
Re: code 36
The code indicates there is a problem with the high resolution pulse signal from the optical cam position sensor in the Opti distributor. The manual indicates the engine will continue to run on the low resolution signal with a minor increase in spark scatter.
Check the short Opti harness that runs from the gray 4-wire connector on the bracket in the middle of the passenger side of the intake manifold to the Opti harness tower. Look for damaged wire and/or damaged or corroded harness connector pins on both ends of the harness. It isn't unusual for a blue corrosion layer to build up on the pins at the Opti end connector and the pins in the Opti harness tower.
Old Aug 2, 2013 | 09:38 AM
NUR2S's Avatar
Re: code 36
thank you for your suggestions-checked opti-harness and used contact cleaner on them-they look fine-installed new maf (brought it back wasn't the solution)-any other suggestions would be appreciated
Old Aug 2, 2013 | 10:31 AM
Re: code 36
Clear the code (pull "PCM BAT" fuse for 30 seconds), and see how fast it comes back.
Old Aug 2, 2013 | 11:49 AM
NUR2S's Avatar
Re: code 36
tried pulling "pcm batt fuse" same condition ses after hard start and 5 secs. later fans come on-one thing I noticed when you shut car off it restarts right away
Old Aug 6, 2013 | 10:29 AM
NUR2S's Avatar
Re: code 36
Still having problems with ses light and fans caomong on after hard start-could it be air pump related?
Old Aug 6, 2013 | 10:47 AM
Re: code 36
AIR pump won't cause hard starts. If you still have a code 36, it's opti related.
Old Aug 6, 2013 | 12:03 PM
NUR2S's Avatar
Re: code 36
thank you shoebox-any suggestions besides replacing opti?
Old Aug 15, 2013 | 03:30 PM
NUR2S's Avatar
Re: code 36
Still need help-hard start and ses light with fans coming on - what do I try next?
Old Aug 15, 2013 | 03:41 PM
slick1hunting's Avatar
There is a sticky at top of forum for testing the opti. I would start by reading it(because I dont have the answer lol).
Posted from Camaroz28.com App for Android
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
