Code 34
Old Mar 25, 2010 | 06:53 PM
edz97's Avatar
Code 34
I just picked up a 1995 Z28, auto, 105000 miles. Bought it cheap non running. Replaced the fuel pump (low pressure) and plugs. I have an ses light and the code is 34 the autoxray is showing 34 MAP/MAF low. The car seems to be running rich. When I replaced the plugs they were black and the exhaust smells rich.
Old Mar 26, 2010 | 05:28 AM
Always use Shoebox's LT1 code list, not the generic readings on the scanner:
http://shbox.com/1/Dtcs.htm
DTC 34 = Manifold Absolute Pressure (MAP) sensor circuit (signal voltage low, high vacuum)
That means the PCM is seeing a MAP voltage/kPa that indicates a vacuum level that the engine is not capable of producing (codes sets when MAP is less than 14kPa). MAP sensor is faulty, or the harness connector is crumbling and making poor contact or shorting.
Old Mar 26, 2010 | 07:52 PM
edz97's Avatar
I went to the auto parts and was going to buy a new MAP sensor, but they don't come with the vacuum seal. I wouldnt be too worried about it but the existing one looks compromised. I am thinking of using an o ring that is thick enough to seal. Will this work. I went to three parts stores and they all have the MAP but no seal.
Old Mar 26, 2010 | 08:52 PM
red 95 z28 lt1's Avatar
get an ac delco map
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
