Code 29, Questions AFTER Forum Search
Old Dec 9, 2004 | 10:49 PM
sharpe's Avatar
I'm getting an error code 29.
First, my search results:
Originally Posted by jare23
Error code 29, EAS electrical fault
anyone heard of this,or know of how to solve the problem? my auto store never even heard of it. any help would be great. thanks.
Originally Posted by shoebox
That's because the code is "Secondary Air Injection (AIR) pump circuit ". Check your AIR pump fuse.
Different thread. Lost who said this, but it received no replies:
My mechanic forgot to put the secondary AIR system back into my rebuild. That may explain why it is not running well. Does anybody have a picture from the top of the motor looking down that details the connections and routing from the exhaust manifolds (now I have shorty headers) to the AIR pump?
Bold added.
A solution, from another thread:
Originally Posted by Injuneer
Check the fuse for the AIR pump. In OBD-I, a blown fuse or relay is the only thing that will set the code. If you replace the fuse, and it continues to blow, just unplug the AIR pump connector, replace the fuse and the SES light will not return. There is a factory recall on the 95 and newer AIR pumps.
Okay, now my questions. What is an AIR pump!? What does it do?
I too am having some very minor low-end power loss. Also, anytime I select something on the far dial (A/C, defrost, etc.), my car stutters. Could these symptoms be a result of the problem represented by code 29?
There is no need to offer suggestions on the low-end power loss. Only on the code 29, please.
Thanks!
Old Dec 9, 2004 | 10:55 PM
Re: Code 29, Questions AFTER Forum Search
The AIR pump is bolted to the drivers side/front of the engine. It pulls air from a nipple on the intake ducting, and blows it into a connection on the top of each exhaust manifold. The pumps runs for about 3 minutes at startup to help the cats heat up.
Of the quotes you listed, I like mine best
Old Dec 9, 2004 | 11:15 PM
sharpe's Avatar
Well, you'll have to admit, you may be a bit bias.
So, you don't think it has anything to do with either of my symptoms? By the way, I don't have a cat if that matters.
Edit: Or, might that be a possible cause of the code?
Old Dec 10, 2004 | 09:00 AM
The missing cat will not set DTC 29. The only thing checked before setting DTC 29 is the integrity of the power supply circuit.
A faulty AIR system will not cause the problems you are having, at least not directly. If you had faulty check valves where the AIR system connects to the exhaust manifolds, it might cause problems. Leaking check valve could cause the pump to corrode, sieze and blow the fuse.
Sounds like you have a vacuum problem. Moving the A/C controls uses the vacuum system. That could be related to a leak in the vacuum system for the controls.
Old Dec 10, 2004 | 03:05 PM
sharpe's Avatar
Okay. Thanks.
Old Dec 10, 2004 | 03:51 PM
Compstall's Avatar
Replacing the 20 amp fuse (popped) two days ago cleared up my Code 29.
Deadbolt24
Jan 19, 2015 01:29 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Dec 1, 2014 08:08 AM
