Code 27?
Old Jul 8, 2015 | 05:26 PM
  #31
z28cam1993's Avatar
Re: Code 27?
No. I never had a chance to check the coil for spark. I had to move car so I just had towed straight to mechanic. I'm going To show him just what you said.
Old Jul 8, 2015 | 06:10 PM
  #32
Re: Code 27?
And you could have scanned it for codes yourself.... DTC 16 sets as soon as you turn the key to crank the engine.
You also indicated you tested for the Opti signal at the ICM. If you had the correct AC voltage on the white wire, you verified the PCM was receiving the low resolution pulse from the Opti.
Old Jul 8, 2015 | 07:18 PM
  #33
z28cam1993's Avatar
Re: Code 27?
I did scan. Code 16 never set. Yes I had all correct voltage. So what else could it be so I don't spend money for no reason. I will show him what you said tom
Old Jul 8, 2015 | 07:21 PM
  #34
z28cam1993's Avatar
Re: Code 27?
Loose ground? I'm totally stumped. remember when I said I looked for spark and when I ground the boot on plug one the engine started and I drove it.
Old Jul 9, 2015 | 11:42 AM
  #35
Re: Code 27?
Originally Posted by Injuneer
Originally Posted by z28cam1993
....... but took the block out of block and with wire connected ground it out and the car started. I drove into house and parked.
You lost me on that one....
I don't understand what you just said you did, and it wasn't real clear before.
Please explain.
Old Jul 9, 2015 | 01:05 PM
  #36
z28cam1993's Avatar
Re: Code 27?
Sorry let me elaborate. I took the boot off of plug 1. I stuck a screwdriver in it and grounded to the engine block to test if they were spark. There seems to be spark at that moment because my friend got shocked and the car started and ran. So I put the book back on at tried to start the car And all it would don there seems to be spark at that moment because my friend got shocked and the car started and ran. So I put the book back on at tried to start is crank.
Old Jul 9, 2015 | 04:24 PM
  #37
z28cam1993's Avatar
Re: Code 27?
Mechanic dug into car and tested the opti it's bad. He temp hooked up the new one and now there is spark. The bad opti is MSD
Old Jul 10, 2015 | 12:10 PM
  #38
Re: Code 27?
Just curious... how do you/he explain that you did a test and verified the Opti pulse signals were getting the the ICM? How do you/he explain that at no time did DTC 16 or DTC 36 set?
Is he basing this on looking at the pulse signal trace on a 'scope, as DelSoto suggested above?
The problem was apparently intermittent, since at one time you had spark and said you drove the car.
Knowing that the old Opti was an MSD would have been useful, because I have seen them produce a sporadic pulse signal. And that can be picked up from a Scan9495 data log.
Or is he possibly saying the rotor came loose, another common problem with the MSD?
Old Jul 10, 2015 | 08:42 PM
  #39
z28cam1993's Avatar
Re: Code 27?
I haven't heard back from the shop yet so I cannot answer your questions but yes seems like was sporadic but I do remember coolant was leaking before sensor was changed right on to opti. Maybe that did it. Also I didn't know till the mechanic told me that is was an MSD opti.
Old Jul 30, 2015 | 01:48 PM
  #40
z28cam1993's Avatar
Re: Code 27?
Ok a little update. Mechanic replaced opti with a brand new one. He says it now starts intermittently. Any idea what to check for now?
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
