code 21 need to slot the tps sensor need help
Old Jun 10, 2008 | 04:23 PM
detroit1994z28's Avatar
Okay heres the deal. I been going threw a ton of throttle position sensors latley and recently I had another code that came up code 21. I have a 58mm Holley throttle body. I heard that you have to slot the tps to adjust the correct voltage. I have a lt1 scanmaster so I can read the voltage of that. Where should the correct voltage be at idle??
Old Jun 10, 2008 | 07:29 PM
joeSS97's Avatar
.20-.90V@ idle... no more than 4.9V at wot...Did a search for you.
Old Jun 10, 2008 | 09:07 PM
cool thanks buddy - Mike
HectorM52
Jul 30, 2017 11:46 AM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
edman
Jan 22, 2015 02:45 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
91Bird305
Aug 5, 2002 01:39 PM
