Code 16, low res opti. But I have spark at the plug??
Old Feb 23, 2004 | 02:29 PM
lons94z's Avatar
I bought a ScanMaster to scan my codes (among other things)
The car WILL NOT START. It used to run but REALLY rich. Eventually it just would not start.
It has a new coil, plugs, wires, ICM. Fuel pressure checked out OK.
I initially got a DTC 48,18,16. I plugged the MAF back in, put the injector fuses back in, and reset the computer.
No codes. After cranking awhile I get the code 16 back.
BUT the plugs will fire a decent blue looking spark.
WHAT IS THE PROBLEM WITH THIS STUPID THING!!!!!!
Thanks for any help!
Old Feb 23, 2004 | 02:37 PM
ledfootz28's Avatar
i threw dtc16 after i installed my opti too.either it was still in there from when my opti went out or i heard if u put the key on acc with the opti harness disconected the pcm will load taht code,i cleared the code by reseting the pcm.either reset the pcm,clean opti harness,or new opti time.gluck
Old Feb 23, 2004 | 02:55 PM
lons94z's Avatar
Two KEY things throw me off.
#1. Supposedly a code 16 will shut down the fuel system. Put my fuel system is NOT shutdown. I have too much fuel.
#2. I still have spark at the plug.
Old Feb 23, 2004 | 02:59 PM
2ZPOINT's Avatar
You can still have spark at the plug,but the thing won't start. Threw me off beore. The optical sensor keeps our timing and stuff too so it could throw all kinds of stuff off. I bet it's the opti.
Old Feb 23, 2004 | 04:49 PM
lons94z's Avatar
ttt
Old Feb 23, 2004 | 05:14 PM
Tires_Smokin's Avatar
Try using a different coil and see what happends...
I did an opti install and then the car still wouldnt start..swapped coil and "walla" it started
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
Jazsun
Dec 29, 2014 12:14 PM
