Code 16,66,77
Old May 31, 2004 | 09:59 AM
lons94z's Avatar
Code 16,66,77
I keep getting these codes. I know the 16 is a low res pulse but it has a brand new opti and runs and starts fine.
The other two I'm not sure about. I know one is a fan relay code but the fans come on like they are supposed to. The only thing I can think of is I rigged a manual fan switch into the relays. I ran a ground wire from the switch right to the battery. When I installed my scan master I ran it's ground wire into the switches ground wire.
What are the codes and why would I be getting them?
Any help appreciated!
Old May 31, 2004 | 11:08 AM
DonHood's Avatar
Diagnostic Trouble Code index
That should get you started. Figuring out why they're being thrown is the fun part.
Old May 31, 2004 | 09:34 PM
Hooking up a "fan" switch can cause the code, unless you wire it correctly. I believe Shoebox has the "fix" on his page:
http://shbox.com/1/4th_gen_tech1.html
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
