Code 1371?
Old Feb 9, 2003 | 01:32 PM
n2oCamaro's Avatar
Code 1371?
A buddy is having troubles getting his 96Z running. First it would start, but would die shortly after. Now it wont start at all. First he had a TPS code so he replaced that, now it shows a 1371. What is this code?
Old Sep 8, 2004 | 11:38 AM
deb's Avatar
deb
Re: Code 1371?
1371 is low resolution code which is one of two things. (I'm an expert on this since having had my mechanic replace an Opti twice and an Ignition Control Module once)
It's either the Opti or the Ignition Control Module. There's a undefined fine gray area... not easily explained.
Good luck...
Old Sep 8, 2004 | 12:53 PM
Re: Code 1371?
Low res pulse missing from Opti. PCM shuts down fuel system, including pump and injectors.
Old Sep 8, 2004 | 02:46 PM
Re: Code 1371?
Take a look at the connecting electrical harness to the opti. Inspect for corrosion, especially at the opti end.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
