code#1351?
Old Apr 29, 2004 | 10:29 AM
RedWS6TA's Avatar
code#1351?
what would cause this code? it says something about a misfire? please help!
Old Apr 29, 2004 | 10:57 AM
HBHRacing's Avatar
P1351 Ignition Control (IC) circuit high voltage (open circuit)
whats the car doing? does it run at all?
Old Apr 29, 2004 | 11:06 AM
RedWS6TA's Avatar
it is running, it idles fine but if i hold the rpm's at about 2200 or higher with the car out of gear it just misses?
Old Apr 29, 2004 | 11:11 AM
HBHRacing's Avatar
i ahve seen the IC code pop up sometimes when there is an issue with the IGN system. the IC ciurcut comes from the computer on teh white wire to the ICM. it should carry verying voltage to tell the ICM when to fire. you might wanna clear the code and see if it resets. I'm wonding if the ICM could be going bad
Old Apr 29, 2004 | 11:21 AM
RedWS6TA's Avatar
what does icm stand for? and i think my buddy who was trying to hook up my shift lite might have messed with wires going to the computer i know they finally got it to work by running a wire to the coil. if that helps any. thanks for you help. any more ideas?
Old Apr 29, 2004 | 11:26 AM
HBHRacing's Avatar
ICM. Ignition control module, it's mounted to teh drivers side head near the coil. what exactly did he tie into and what do you mean you ran a wire to the coil?
Old Apr 29, 2004 | 11:28 AM
RedWS6TA's Avatar
we could not figure out which wire to splice into to make the shift lite work. i mean it had power but the wire that let it read the rpm's. and in the instructions it said that you could hook it up somehow to the coil. i dont have the insructions on me but i know the shift lite works now. but i am wondering if that has something to do with why it is doing this?
